Acer B276HULCymiidprzx 27" 2560x1440 6ms HDMI DVI DP USB Monitor
Quicklinx: CP9KWS00 Mfr#: UM.HB6EE.C05
Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Acer B276HULCbmiidprzx - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Dark grey
63.97 cm x 24.71 cm x 40.66 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3-year warranty
TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X3 TMX3410-M-52M7; X5 TMX514-51-560Q, TMX514-51T-54EG
Display Type
Energy Class
Class G
58 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 8-bit gamma
Dark grey
63.97 cm x 24.71 cm x 40.66 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DVI-D (dual link) (HDCP) , DisplayPort , DisplayPort output , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Integrated cable management, portrait / landscape mode, VESA interface support, USB 3.0 port power off USB charging
1 x DVI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
Input Voltage
40 W
32.1 kWh/1000h
Power Consumption Stand by
0.36 Watt
Power Consumption (Off Mode)
0.25 Watt
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 24.71 cm - height: 40.66 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Acer TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X3 TMX3410-M-52M7 , Acer TravelMate X5 TMX514-51-560Q, TMX514-51T-54EG
