Your basket is empty
Acer B276HULA 27" 2560x1440 6ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: 9L9GWS00 Mfr#: UM.HB6EE.A01
Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Acer B276HUL - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
64 cm x 24.7 cm x 55.8 cm
8.51 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
66 kWh
45 W
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
64 cm x 24.7 cm x 55.8 cm - with stand
8.51 kg
Audio
Speakers
2 x HDMI , DVI-D , DisplayPort , 2 x USB 3.0 , DisplayPort output , 2 x USB , Audio line-in
1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
TCO Displays 6.0
AC 120/230 V
32.8 Watt
Power Consumption Stand by
490 mW
Power Consumption Sleep
350 mW
On / Off Switch
Dimensions & Weight Details
With stand - width: 64 cm - depth: 24.7 cm - height: 55.8 cm - weight: 8.51 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 6 kg
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
9L9G C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9L9G C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
9L9G C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
9L9G C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
9L9G C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
9L9G C2G Pro HDMI to VGA Converter In Stock £46.35
