Acer B276HLCymdprx 27" 1920x1080 VGA DVI DP Monitor
Quicklinx: CPF5WS00 Mfr#: UM.HB6EE.C01
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. Acer EcoDisplay Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. ComfyView Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. ErgoStand The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
Acer B276HLCbmdprx - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Dark grey
63.97 cm x 22.09 cm x 40.66 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X3 TMX3410-M-52M7; X5 TMX514-51-560Q, TMX514-51T-54EG
Display Type
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma
Dark grey
63.97 cm x 22.09 cm x 40.66 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , DisplayPort , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
VESA interface support
Stand
1 x VGA cable - VGA to VGA , 1 x DVI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 22.09 cm - height: 40.66 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X3 TMX3410-M-52M7 , Acer TravelMate X5 TMX514-51-560Q, TMX514-51T-54EG
