Acer B276HKymjdpprz 27" 3840x2160 6ms DVI HDMI DP MiniDP 4K IPS
Quicklinx: 9T6KWS00 Mfr#: UM.HB6EE.009
Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
  • Sharp details
    Focus more clearly on your tasks thanks to the very high resolution of these monitors. Choose from WQHD resolution all the way up to Ultra HD (4K2K) resolution, which delivers four times more pixels and detail than Full HD.
  • Comfortable computing
    Work comfortably for hours with Acer B6 Series monitors. Acer ComfyView technology reduces glare, for greater eye comfort. In-Plane-Switching technology lets you see perfect images from wide viewing angles, for even more clarity and comfort.
  • Brilliant colors
    These monitors deliver 100% sRGB coverage, for perfectly recreated colors. Some models feature 6-axis color adjustment, which lets you fine-tune the colors for amazing color accuracy.
  • Flexible design
    Find a working angle that's perfect for you with the Acer ErgoStand, a stand that lets you easily adjust the screen's height, as well as letting you tilt and swivel it easily. Another great feature of the ErgoStand is that it allows you to effortlessly rotate the screen to portrait mode.
Acer B276HK - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
75 kWh
Power Consumption (On mode)
32.1 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Input Connectors
DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Dark grey
62.4 cm x 24.7 cm x 55 cm
7.82 kg
United Kingdom, Europe, EMEA
Microsoft Certification
Compatible with Windows 7
Display Type
Energy Class
Class G
75 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
6 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
Dark grey
62.4 cm x 24.7 cm x 55 cm - with stand
7.82 kg
Audio
Speakers
MHL / HDMI , DVI , Mini DisplayPort , USB 3.0 , DisplayPort
Mechanical
Tilt Angle
-5/+35
1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
32.1 W
32.1 kWh/1000h
Power Consumption (Typical)
44.3 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
Dimensions & Weight Details
With stand - width: 62.4 cm - depth: 24.7 cm - height: 55 cm - weight: 7.82 kg , Without stand - width: 62.4 cm - depth: 6.4 cm - height: 37 cm - weight: 5 kg
9T6K C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
