Acer B276HKBymjdpprzx 27" 3840x2160 6ms DVI HDMI DP USB Monitor
Quicklinx: CP9GWS00 Mfr#: UM.HB6EE.B02
Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
  • Sharp details
    Focus more clearly on your tasks thanks to the very high resolution of these monitors. Choose from WQHD resolution all the way up to Ultra HD (4K2K) resolution, which delivers four times more pixels and detail than Full HD.
  • Comfortable computing
    Work comfortably for hours with Acer B6 Series monitors. Acer ComfyView technology reduces glare, for greater eye comfort. In-Plane-Switching technology lets you see perfect images from wide viewing angles, for even more clarity and comfort.
  • Brilliant colors
    These monitors deliver 100% sRGB coverage, for perfectly recreated colors. Some models feature 6-axis color adjustment, which lets you fine-tune the colors for amazing color accuracy.
  • Flexible design
    Find a working angle that's perfect for you with the Acer ErgoStand, a stand that lets you easily adjust the screen's height, as well as letting you tilt and swivel it easily. Another great feature of the ErgoStand is that it allows you to effortlessly rotate the screen to portrait mode.
Acer B276HK - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
32.1 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Voltage
Dark grey
Environmental Standards
ENERGY STAR Qualified
RoHS
3-year warranty
Display Type
Energy Class
Class G
38 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 10-bit gamma, Zero Frame
Dark grey
DVI-D (dual link) (HDCP) , MHL / HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Height Adjustment
100 mm
RoHS
Input Voltage
32.1 W
32.1 kWh/1000h
Power Consumption (Typical)
44.3 Watt
Power Consumption Stand by
450 mW
Dimensions & Weight Details
With stand - width: 62.4 cm - depth: 24.7 cm - height: 55 cm - weight: 7.82 kg , With stand - width: 62.4 cm - depth: 24.7 cm - height: 55 cm - weight: 7.82 kg , Without stand - width: 62.4 cm - depth: 6.4 cm - height: 37 cm - weight: 5 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
