Acer B247Y 23.8" 1920x1080 4ms Full HD HDMI VGA LED Monitor
Quicklinx: F1P9WS00 Mfr#: UM.QB7EE.001
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£137.07 ex VAT
£164.48 inc VAT
Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. In the professional world, accuracy is everything. Utilize color-enhancing and eye-care technologies for pinpoint precision.
  • ZeroFrame design
    The near bezelless design creates a more seamless look, allowing you to see more of what matters most: the screen.
  • A strong, ergonomic edge
    Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
  • Built-in speaker
    The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • A wide range of color
    sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
  • Designed for accuracy
    Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
Acer B247Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54 cm x 19.3 cm x 49.9 cm
5.59 kg
Belgium
Directive 1275/2008, TCO Displays, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EN 61000-3-3:2013, EN 55024:2010, ErP 2009/125/EC, TUV Rheinland, EMC 2014/30/EU, LVD 2014/35/EU, EN 55032:2012+AC:2013 Class B, IEC/EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, EN 61000-3-2:2014 Class D
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology
54 cm x 19.3 cm x 49.9 cm - with stand
5.59 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
VGA , DisplayPort , HDMI , Audio line-out
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
120 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x DisplayPort cable
Belgium
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
Dimensions & Weight Details
With stand - width: 54 cm - depth: 19.3 cm - height: 49.9 cm - weight: 5.59 kg , Without stand - width: 54.1 cm - depth: 6.6 cm - height: 32.3 cm - weight: 3.64 kg
Acer B247Y 23.8 Bundle deal on Acer B247Y 23.8" 1920x1080 4ms Full HD HDMI VGA LED Monitor
£236.83
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
