Acer B246HLCymipruzx 24" 1920x1080 VGA DVI HDMI USB Monitor
Quicklinx: CPF3WS00 Mfr#: UM.FB6EE.C01
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£210.19 ex VAT
£252.22 inc VAT
Ideal for use in office environments, libraries and computer labs, Professional series monitor delivers dynamic and energizing visuals. This monitor features eco-friendly technologies that save power and cut energy costs. It is also ergonomically designed, with a slim and clean-cut look.
Acer B246HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
USB 3.1 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Dark grey
56.7 cm x 22.12 cm x 38.39 cm
6.09 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, DDC-2B, NOM, FCC Part 15 B, CCC, EMC, DDC/CI, RoHS, WEEE, cCSAus, Directive 2009/125/EC, TCO Displays 6.0, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN55024:2010, EN61000-3-3:2008, EMC 2004/108/EC, LVD 2006/95/EC, EN 55022:2006+A1:2007 Class B, EN50581:2012, N 61000-3-2:2006+A1:2009+A2:2009 Class D, TUV Rheinland GS
3-year warranty
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
24"
Built-in Devices
USB 3.1 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
ErgoStand, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Acer Empowering Technology, Acer eColor technology
Dark grey
56.7 cm x 22.12 cm x 38.39 cm - with stand
6.09 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , DisplayPort , 4 x USB 3.1 downstream , USB 3.1 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support, USB 3.0 port power off USB charging
1 x DisplayPort cable , USB-C cable
Security Slot Type
Kensington security slot
20.9 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 22.12 cm - height: 38.39 cm - weight: 6.09 kg , Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
5 °C
35 °C
10 - 85%
Acer B246HLCymipruzx 24 Bundle deal on Acer B246HLCymipruzx 24" 1920x1080 VGA DVI HDMI USB Monitor
£309.95
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
