Acer B226HQLymdr 21.5" 1920x1080 VGA DVI Monitor
Quicklinx: CPFJWS00 Mfr#: UM.WB6EE.001
Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Acer B226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
Dark grey
50.8 cm x 22.1 cm x 36.9 cm
5.81 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (On/Off)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
ErgoStand, HDCP, Acer EcoDisplay, ComfyView, 72% NTSC colour gamut
Dark grey
5.81 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
MTBF
30,000 hour(s)
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
16.5 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 22.1 cm - height: 36.9 cm - weight: 5.81 kg , Without stand - width: 50.8 cm - height: 30.4 cm - weight: 3.17 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
