Acer B226HQLA 21.5" 1920x1080 8ms DVI HDMI LED Monitor
Quicklinx: 9LB9WS00 Mfr#: UM.WB6EE.A07
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£127.93 ex VAT
£153.51 inc VAT
Ideal for use in office environments, libraries and computer labs, Professional Series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Display Type
Energy Class
Class A
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
19 W
Diagonal Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, ComfyView
Dark grey
50.8 cm x 20.43 cm x 36.82 cm
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI , HDMI
Mechanical
Display Position Adjustments
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V
19.5 Watt
Power Consumption Sleep
0.35 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.43 cm - height: 36.82 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
Environmental Standards
ENERGY STAR Certified
Limited warranty - 3 years
Acer B226HQLA 21.5 Bundle deal on Acer B226HQLA 21.5" 1920x1080 8ms DVI HDMI LED Monitor
£227.10
9LB9 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9LB9 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.62
9LB9 C2G 5m Select High Speed HDMI with Ethernet In Stock £22.12
9LB9 C2G 10m Select High Speed HDMI with Ethernet In Stock £42.46
9LB9 C2G 15m Select High Speed HDMI with Ethernet In Stock £57.52
Response Time: 8ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
