Ideal for use in office environments, libraries and computer labs, professional series monitors deliver dynamic and energizing visuals. This monitor features eco-friendly technologies that save power and cut energy costs. It is also ergonomically designed, with a slim and clean-cut look.
- Acer B196L - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Class
- Class F
- Power Consumption (On mode)
- 17.5 W
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Dark grey
- Environmental Standards
- TCO Certified Displays 8
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP
- Dark grey
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DVI (HDCP)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- AC 120/230 V
- 17.5 W
- Power Consumption SDR (On mode)
- 17.5 kWh/1000h
- Power Consumption (Typical)
- 15.8 Watt
- Power Consumption Sleep
- 0.45 Watt
Sustainability Information
- TCO Certified
