Product
Acer B196LAymdr 19" 1280x1024 VGA DVI Monitor
Quicklinx: CPFHWS00 Mfr#: UM.CB6EE.A01
Ideal for use in office environments, libraries and computer labs, professional series monitors deliver dynamic and energizing visuals. This monitor features eco-friendly technologies that save power and cut energy costs. It is also ergonomically designed, with a slim and clean-cut look.
Acer B196L - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Screen Coating
Anti-glare
Dark grey
TCO Displays 7.0
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP
Dark grey
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
1 x VGA cable , 1 x DVI cable
TCO Displays 7.0
AC 120/230 V
15.8 Watt
Power Consumption Sleep
0.45 Watt
