Acer Asprie Pro R7-372T Pro Core i5 6200U 8GB 128GB SSD 13.3" Windows 10 Professional
Quicklinx: C4XRWS00 Mfr#: NX.G8SEK.001
  • Core i5
  • IEEE 802.11n
The Aspire R 13 boasts intelligent construction and smart features that enhance work and play. Thanks to the futuristic Ezel Aero Hinge, you can transition effortlessly between six different user modes. Masterfully crafted with premium features such as Corning Gorilla Glass 3, a WQHD screen and the Acer Active Pen, the Aspire R 13 is a laptop that might just change.
  • Smart hinge, great flexibility
    Acer's innovative Ezel Aero Hinge features two separate hinge mechanisms that work together to allow seamless transition between six user modes. This fantastic hinge also keeps the display very stable when you use it for touch control.
  • Thin, light, and tough
    The touchscreen and its back cover are encased in two slices of Corning Gorilla Glass 3 - which makes the top panel very tough, beautiful, and strikingly slender. At only 1 inch thin (17.95 mm) thin, the Aspire R 13 is a joy to pack and carry.
  • A pen for your thoughts
    The Aspire R 13's touchscreen works perfectly with the Acer Active Pen, which uses Acer Hover Access technology to activate pop-up, tap-on menus. The result is a more intuitive writing experience that is also very convenient, fun and productive.
  • Visual delight
    You can choose between a WQHD display with power-saving IGZO technology that delivers super-crisp images, or a full HD display with wide viewing angles (IPS technology) and optical clarity solutions. All models feature direct bonding (zero air gap) for a brighter, crisper display.
  • Cinematic surround sound
    Immerse yourself in movies with dolby digital plus home theater - sound technology that is crafted to bring every movie to life and put you in the middle of the action.
  • Comfortable viewing
    Corning's AR/ETC (antireflective and easy-to-clean) glass coating reduces screen glare and improves contrast, while also making it very easy to clean the screen. A built-in light sensor auto-adjusts brightness levels to further enhance eye comfort and power efficiency.
  • Great video conferencing
    This laptop has dual-array microphones for noise-free voice communication. Acer Purified. Voice technology tracks the voice of the speaker as he or she moves around the room. The Aspire R 13 is also skype certified because it has all the high-quality hardware required for great audio and video chats.
Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 128 GB SSD - UK
Notebook - flip-hinge design
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB LPDDR3
Storage
128 GB SSD
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac
4-cell
Grey
34.38 cm x 23.035 cm x 1.85 cm
1.6 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
LPDDR3 SDRAM
Storage
Main Storage
128 GB SSD M.2
Display
13.3"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, Corning Gorilla glass 3
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Camera Features
HDR (High Dynamic Range), 720p HD movie recording
Sound
Stereo speakers, microphone
Dolby Digital Plus Home Theater
Audio Features
Output: Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
M.2 Card
4-cell
3315 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB 2.0 , 2 x USB 3.0 , HDMI , Headphone/microphone combo jack , USB-C (supports Thunderbolt 3)
Grey
Security lock slot (cable lock sold separately), volume control, Acer Purified.Voice technology, MU-MIMO technology
Power adapter
ACPI 5.0
Localization
1.6 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
