Acer Aspire Z1-622 Pentium J3710 4GB 1TB 21.5" Windows 10
Quicklinx: CM1RWS00 Mfr#: DQ.B5FEK.001
  • Pentium
  • IEEE 802.11n
Acer Z1 series all-in-one PC will save space and add style to any room in your house. It combines eco-friendly performance with stunning sights and sounds, making it perfect for everyday computing and entertainment. What's more, there's a touch display that'll add a dimension to your digital life.
  • Stellar performance
    A powerful processor makes daily computing tasks easier than ever. Download and store all of the multimedia files you crave on the hard disk drive. Your PC running is always fast and smooth.
  • Space-saving design
    VESA-compatible holes and a detachable stand allow the streamlined Z1 series all-in-one to be hung on a wall, or it can stand alone on your desk. Either way, you'll appreciate a larger, cleaner work space!
  • High-definition enjoyment
    Excellent video and audio transform the Z1 series into your personal home entertainment system. With powerful high-definition graphics and crystal-clear sound, you'll enjoy movie nights in the comfort of your living room.
  • Eco-friendly savings
    The green-certified Z1 series consumes less than 1 W in power-off mode. You get great performance while conserving resources and saving money.
Acer Aspire Z1-622_QubJ3710 - all-in-one - Pentium J3710 1.6 GHz - 4 GB - HDD 1 TB - LED 21.5"
Personal computer - all-in-one
Region: United Kingdom
Intel Pentium J3710 / 1.6 GHz (, up to 2.64 GHz, (Quad-Core)
Processor Main Features
Intel Burst Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB DDR3L SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD SuperMulti
Card Reader
Monitor
21.5" - LED - 1920 x 1080 (Full HD)
Graphics Controller
Intel HD Graphics 405
GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
OS Provided
Windows 10 Home 64-bit Edition
52.6 cm x 3.48 cm x 34.2 cm
4.3 kg
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Processor / Chipset
CPU
Intel Pentium J3710
Clock Speed
1.6 GHz
Max Turbo Speed
2.64 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB
DDR3L SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
LED
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Response Time
5 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Interface (Bus) Type
M.2 Card
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Slots
1 (total) / 0 (free) x CPU , SO-DIMM 204-pin
1 x LAN , 1 x HDMI input , 3 x USB 2.0 , 1 x headphones/microphone
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
52.6 cm
3.48 cm
34.2 cm
4.3 kg
