Acer Z1 series all-in-one PC will save space and add style to any room in your house. It combines eco-friendly performance with stunning sights and sounds, making it perfect for everyday computing and entertainment. What's more, there's a touch display that'll add a dimension to your digital life.
Stellar performance
A powerful processor makes daily computing tasks easier than ever. Download and store all of the multimedia files you crave on the hard disk drive. Your PC running is always fast and smooth. -
Space-saving design
VESA-compatible holes and a detachable stand allow the streamlined Z1 series all-in-one to be hung on a wall, or it can stand alone on your desk. Either way, you'll appreciate a larger, cleaner work space. -
High-definition enjoyment
Excellent video and audio transform the Z1 series into your personal home entertainment system. With powerful high-definition graphics and crystal-clear sound, you'll enjoy movie nights in the comfort of your living room. -
Eco-friendly savings
The green-certified Z1 series consumes less in power-off mode. You get great performance while conserving resources and saving money.
- Acer Aspire Z1-602_LubN3050 - all-in-one - Celeron N3050 1.6 GHz - 4 GB - HDD 500 GB - LED 18.5"
- Personal computer - all-in-one
- Localisation
- Region: United Kingdom
- Processor
- Intel Celeron N3050 / 1.6 GHz (, up to 2.16 GHz, (Dual-Core)
- Processor Main Features
- Intel Burst Technology
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 4 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Monitor
- 18.5" - LED - 1366 x 768 (HD)
- Graphics Controller
- Intel HD Graphics
- Networking
- GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
- OS Provided
- Windows 10 Home 64-bit Edition
- 29.5 cm x 2.99 cm x 45.2 cm
- 4 kg
- Personal computer
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.6 GHz
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED
- Diagonal Size
- 18.5"
- Native Resolution
- 1366 x 768 (HD)
- Widescreen Display
- Response Time
- 5 ms
- Image Brightness
- 200 cd/m²
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Intel HD Graphics
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Resolution (MP)
- 1 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Slots
- 1 (total) / 0 (free) x CPU , 1 Mini PCIe , SO-DIMM 204-pin
- 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 3 x USB 2.0 , 1 x audio line-out , 1 x USB 3.0
- BSMI, CB, CCC, FCC, RoHS
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 29.5 cm
- 2.99 cm
- 45.2 cm
- 4 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
