Acer Aspire XC-710 Core i3-6100 8GB 1TB Free DOS
Quicklinx: C55BWS00 Mfr#: DT.B1REK.006
  • Core i3
  • IEEE 802.11n
Maximize your creativity and your desk space, too. Small enough to fit anywhere, the compactly styled Aspire X series is just one-third the size of a tower PC, yet it offers plenty of power and performance for your multimedia creativity and HD entertainment.
  • Fit in well
    Easy to place, easy to set up: whether on a bookcase shelf, in a corner of your desk, or tucked underneath, this compact PC just fits. It's perfect for storing movies and media, as a gaming or learning machine in the kids' room, or as a homework tool for students in cramped dorms.
  • Full power
    Finish tasks, watch programming, play casual games, and keep in touch with friends - all easy with high-capacity processing. Press the blue LED power button and command your world.
  • HD fun
    Wonderfully compact and wonderfully entertaining: the Aspire X series is your high-definition multimedia center. Plus, you can easily take the multimedia experience to your big screen, thanks to the HDMI port integrated on every Aspire X series desktop.
  • Expandable
    Transfer media easily from your digital devices using the front card reader or swift USB 3.0 ports.
Acer Aspire XC-710_H_WLP - SFF - Core i3 6100 3.7 GHz - 8 GB - HDD 1 TB
Personal computer - small form factor
Region: United Kingdom
Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB DDR3L SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
AMD Radeon R7 340
Video Memory
2 GB
Audio Output
5.1 channel surround
GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
AC 230V
OS Provided
FreeDOS
10 cm x 39.77 cm x 27.75 cm
5.25 kg
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB
DDR3L SDRAM
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7 340
Video Memory
2 GB
Video Interfaces
DVI, HDMI
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Bays
External 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU , DIMM 240-pin
2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (2 front, 2 rear) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x HDMI , 1 x DVI
Wireless antenna
BSMI, CB, FCC, RoHS, PC 2001
Power supply
AC 230V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
FreeDOS
10 cm
39.77 cm
27.75 cm
5.25 kg
