Maximize your creativity and your desk space, too. Small enough to fit anywhere, the compactly styled Aspire X series is just one-third the size of a tower PC, yet it offers plenty of power and performance for your multimedia creativity and HD entertainment - and your media is shareable in AcerCloud.
Easy to place, easy to set up
Whether on a bookcase shelf, in a corner of your desk, or tucked underneath, this compact PC just fits. It's perfect for storing movies and media, as a gaming or learning machine in the kids' room, or as a homework tool for students in cramped dorms. -
Full power
Finish tasks, watch programming, play casual games, and keep in touch with friends - all easy with a powerful processor. Press the blue LED power button and command your world. -
Wonderfully compact - and wonderfully entertaining
The Aspire X series is your high-definition multimedia center. Plus, you can easily take the multimedia experience to your big screen, thanks to the HDMI port integrated on every Aspire X series desktop. -
Transfer media easily
Transfer media easily from your digital devices using the front card reader or swift USB 3.0 ports.
- Acer Aspire XC-705_W - SFF - Pentium G3250 3.2 GHz - 6 GB - HDD 1 TB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Pentium G3250 / 3.2 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 6 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- Intel HD Graphics
- Audio Output
- 5.1 channel surround - integrated
- Networking
- GigE, Bluetooth, 802.11b/g/n
- Power
- AC 230V
- OS Provided
- Windows 8.1 64-bit Edition
- 36.7 cm x 26.95 cm x 10 cm
- 9 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- 6 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB + 1 x 2 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x DIMM 240-pin , 1 (total) / 0 (free) x Mini PCIe , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe x16
- 4 x USB 2.0 , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 (2 in front) , 1 x audio line-in
- BSMI, CB, RoHS, PC 2001, EuP
- Power supply
- Voltage Required
- AC 230V
- Power Provided
- 220 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 36.7 cm
- 26.95 cm
- 10 cm
- 9 kg
