Maximize your creativity and your desk space, too. Small enough to fit almost anywhere, the compact Aspire X Series is just one-third the size of a tower PC, yet offers plenty of power and performance for your multimedia creativity and HD entertainment - plus, your all your media is shareable using Acer BYOC Apps.
Fit in well
Easy to place, easy to set up: whether on a bookcase shelf, in a corner of your desk, or tucked underneath, this compact PC just fits. It's perfect for storing movies and media, as a gaming or learning machine in the kids' room, or as a homework tool for students in cramped dorms. -
Full power
Finish tasks, watch programming, play casual games, and keep in touch with friends - all easy with great processing, and excellent graphics discrete cards. Press the LED power button and command your world. -
Expandable
Transfer media easily from your digital devices using the front card reader or swift USB 3.0 ports.
- Acer Aspire XC-217_WA86410 - SFF - A8 6410 2 GHz - 8 GB - HDD 2 TB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- AMD A8 6410 / 2 GHz (, up to 2.4 GHz, (Quad-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 8 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 2 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- AMD Radeon R5 310
- Video Memory
- 2 GB
- Networking
- GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- 10 cm x 38 cm x 27.7 cm
- 3 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- AMD A8 6410
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R5 310
- Video Memory
- 2 GB
- Video Interfaces
- DVI, HDMI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 5.25" , 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , DIMM 240-pin
- 3 x USB 3.0 (2 front, 1 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x HDMI , 1 x DVI
- Included Accessories
- Wireless antenna
- Power adapter
- Voltage Required
- (50/60 Hz)
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
- 10 cm
- 38 cm
- 27.7 cm
- 3 kg
