The sleek and compact Aspire X3 Series is just one-third the size of a traditional PC, allowing it to fit anywhere in your home. This desktop features high-quality components and software, perfect for handling your home computing and entertainment needs. Moreover, lots of multimedia features and device ports let you enjoy theater-quality entertainment right in your living room.
Rich HD experience
Watch the latest Blu-ray movies with true theater-like imagery and high-definition audio support from the comfort of your couch. And, with the HDMI port, you can connect your PC to big-screen peripheral displays, including your main home entertainment center. -
Easy expandability
With expandable DD3 memory, this desktop promises speedy multitasking while using 20% less power. Large storage capacity means you have ample room to keep all your files. And a multi-in-1 card reader and numerous USB ports make it easy to manipulate and share your files. -
Neat style
At just one-third the size of a traditional PC, this desktop is easy to set up. A small door at the bottom opens for easy access to USB ports, audio ports, and the multi-in-1 card reader. What's more, the power button lights up in bright blue when turned on, so it looks cool and is easy to find.
- Acer Aspire X3-710_W - SFF - Core i5 6400 2.7 GHz - 8 GB - HDD 2 TB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 8 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 2 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- PCIe x16 - NVIDIA GeForce GT 730
- Video Memory
- 2 GB DDR3 VRAM
- Audio Output
- 5.1 channel surround
- Networking
- GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
- Power
- AC 230V
- OS Provided
- Windows 10 Home 64-bit Edition
- 10 cm x 37.15 cm x 28.18 cm
- 9 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 2 GB DDR3 VRAM
- Video Interfaces
- DVI, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
- Interface
- RF
Mouse
- Connectivity
- Wireless
- Interface
- RF
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- Internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 1 PCIe x16 , 1 PCIe x4 , DIMM 240-pin
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in , 2 x HDMI output
- Included Accessories
- Wireless antenna
- BSMI, CB, CCC, FCC
- Power supply
- Voltage Required
- AC 230V
- Power Provided
- 220 Watt
Operating System / Software
- OS Provided
- 10 cm
- 37.15 cm
- 28.18 cm
- 9 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
