Pick up the Aspire R, and you'll see the world. Because with a powerful computer fluidly moving between four modes, there are no limits to the work that can be created, moments shared, games played, connections made. Discover a computer that's everything you need it to be.
360-degree dual-torque hinge
The 360-degree dual-torque hinge offers easy one-handed conversion and a wobble-free touch experience. The laptop also lays 180 degrees flat for collaboration and sharing. -
Zero Air Gap
Zero Air Gap technology unites touch and sight better than ever for a truly impressive touchscreen experience. This technology directly bonds the touch panel to the LCD, significantly reducing reflection while improving contrast and image clarity, especially in bright light. -
Matches your moves
When you flip the Aspire R display to switch modes, the audio channels and video display automatically reverse to the correct orientation. You can also set default wallpapers for each mode.
- Acer Aspire R 15 R5-571T-5711 - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 9 hour(s)
- G-sensor
- Steel grey
- 37.07 cm x 25.62 cm x 1.996 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 270 cd/m²
- HDCP, glare, CineCrystal
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Sound
- Speakers, subwoofer, two microphones
- Dolby Audio Premium
- Audio Features
- Output: Acer TrueHarmony Plus technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 3220 mAh
- Run Time
- Up to 9 hour(s)
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB-C , USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , USB 3.0 (with power off charging)
- Memory Card Reader
- Yes (SD Card)
- Steel grey
- Case Material
- Anodised aluminium
- Integrated Options
- G-sensor
- Accelerometer, Acer BluelightShield technology
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
