Acer Aspire R5-571T Core i5-6200U 8GB 256GB 15.6" Windows 10 Steel Grey
Quicklinx: CFZSWS00 Mfr#: NX.GCCEK.009
  • Core i5
  • IEEE 802.11n
Pick up the Aspire R, and you'll see the world. Because with a powerful computer fluidly moving between four modes, there are no limits to the work that can be created, moments shared, games played, connections made. Discover a computer that's everything you need it to be.
  • 360-degree dual-torque hinge
    The 360-degree dual-torque hinge offers easy one-handed conversion and a wobble-free touch experience. The laptop also lays 180 degrees flat for collaboration and sharing.
  • Zero Air Gap
    Zero Air Gap technology unites touch and sight better than ever for a truly impressive touchscreen experience. This technology directly bonds the touch panel to the LCD, significantly reducing reflection while improving contrast and image clarity, especially in bright light.
  • Matches your moves
    When you flip the Aspire R display to switch modes, the audio channels and video display automatically reverse to the correct orientation. You can also set default wallpapers for each mode.
Acer Aspire R 15 R5-571T-5711 - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Home 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 9 hour(s)
G-sensor
Steel grey
37.07 cm x 25.62 cm x 1.996 cm
2.4 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
12 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
270 cd/m²
HDCP, glare, CineCrystal
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Sound
Speakers, subwoofer, two microphones
Dolby Audio Premium
Audio Features
Output: Acer TrueHarmony Plus technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Precision touchpad
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
3220 mAh
Run Time
Up to 9 hour(s)
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB 3.0 , USB-C , USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , USB 3.0 (with power off charging)
Memory Card Reader
Yes (SD Card)
Steel grey
Case Material
Anodised aluminium
Integrated Options
G-sensor
Accelerometer, Acer BluelightShield technology
Power adapter
Localization
2.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
