Acer Aspire R3-131T Quad-Core N370 4GB 500GB 11.6" Touch Win 10 H
Quicklinx: CFZPWS00 Mfr#: NX.G0YEK.041
  • Pentium
  • IEEE 802.11n
The Aspire R 11 is a compact convertible notebook that can adapt to any environment. Whether you're at home or in a crowded subway car during rush hour, it gives you four distinct modes to choose from - notebook, display, tent or pad - giving you the flexibility to use it comfortably anywhere.
  • Flip it 360°
    With its 360° dual-torque hinge, you can flip its screen all the way around and everything in between. It lets you enjoy smooth transitions between its four modes, while also offering you a wobble-free screen for a steady touch control experience.
  • Carefree mobility
    The Aspire R 11 is designed to give you peace of mind on the go. The screen is covered with damage-resistant Corning Gorilla glass so you don't have to fret about getting it scratched. Plus long-lasting battery life, it's got enough juice to last you though your entire journey.
  • Smart features
    The Aspire R 11 sports Acer BluelightShield, which helps reduce eye-strain. Plus with Acer Touch Tools you can easily capture and share what's on your screen with touch, while precision touchpad gives you a more fluid zooming and scrolling experience.
Acer Aspire R 11 R3-131T-P2AV - 11.6" - Intel Pentium - N3710 - 4 GB RAM - 500 GB HDD
Notebook - flip design
Operating System
Win 10 Home 64-bit
Intel Pentium N3710 / 1.6 GHz, up to 2.56 GHz / 2 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 405
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac, 10/100 Ethernet
4-cell
G-sensor
Black, blue
29.8 cm x 21.1 cm x 2.09 cm
1.5 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.56 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA / 5400 rpm
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
HDCP, frameless, glare, CineCrystal
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165 - M.2 Card
Network Interface
10/100 Ethernet
4-cell lithium polymer
3270 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB 2.0 , Headphone output , HDMI , LAN , USB 3.0
Memory Card Reader
Yes (SD Card)
Black, blue
Integrated Options
G-sensor
MIMO technology
Power adapter
ACPI 5.0
Localization
1.5 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
