Acer Aspire R3-131T Intel Pentium 4GB 500B 11.6" Windows 10 64-bit
Quicklinx: BQVSWS00 Mfr#: NX.G0YEK.034
  • Pentium
  • IEEE 802.11n
Pick up the Aspire R, and you'll see the world. Because with a powerful computer fluidly moving between four modes, there are no limits to the work that can be created, moments shared, games played, connections made. Discover a computer that's everything you need it to be.
  • 360-degree dual-torque hinge
    The 360-degree dual-torque hinge offers easy one-handed conversion and a wobble-free touch experience. The laptop also lays 180 degrees flat for collaboration and sharing.
  • Zero Air Gap
    Zero Air Gap technology unites touch and sight better than ever for a truly impressive touchscreen experience. This technology directly bonds the touch panel to the LCD, significantly reducing reflection while improving contrast and image clarity, especially in bright light.
  • Matches your moves
    When you flip the Aspire R display to switch modes, the audio channels and video display automatically reverse to the correct orientation. You can also set default wallpapers for each mode.
Acer Aspire R 11 R3-131T-P02Q - 11.6" - Intel Pentium - N3700 - 4 GB RAM - 500 GB HDD - UK
Notebook - flip design
Operating System
Win 10 Home 64-bit
Intel Pentium N3700 / 1.6 GHz, up to 2.4 GHz / 2 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, 10/100 Ethernet
4-cell
G-sensor
Black, blue
29.8 cm x 21.1 cm x 2.09 cm
1.58 kg
Region: United Kingdom
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA / 5400 rpm
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Ultra Slim Design, HDCP, frameless, glare, CineCrystal, Mercury free
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3165 - M.2 Card
Network Interface
10/100 Ethernet
4-cell lithium polymer
3270 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
USB 2.0 , Headphone output , HDMI , LAN , USB 3.0
Memory Card Reader
Yes (SD Card)
Black, blue
Integrated Options
G-sensor
MIMO technology
Power adapter
ACPI 5.0
Localization
1.58 kg
