The Aspire R 11 is a compact convertible notebook that can adapt to any environment. Whether you are at home or in a crowded subway car during rush hour, it gives you four distinct modes to choose from - notebook, display, tent or pad – giving you the flexibility to use it comfortably anywhere.
Flip it 360-degree
With its dual-torque hinge, you can flip its screen all the way around and everything in between. It lets you enjoy smooth transitions between its four modes, while also offering you a wobble-free screen for a steady touch control experience. -
Carefree mobility
The Aspire R 11 is designed to give you peace of mind on the go. The screen is covered with damage-resistant Corning Gorilla Glass so you don't have to fret about getting it scratched. Plus with its long battery life, it's got enough juice to last you though your entire journey. -
Fun on the run
Enjoy features that make entertainment on the go even more gratifying. They include Zero Air Gap, a display technology that improves contrast and image clarity, even under sunlight. Also with Acer TrueHarmony you can revel in fuller and crisper audio, while its auto-reversing speakers optimize sound for each mode. -
Smart features
The Aspire R 11 sports Acer BluelightShield, which helps reduce eye-strain. Plus its precision touchpad gives you a more fluid zooming and scrolling experience.
- Acer Aspire R 11 R3-131T-C3SX - 11.6" - Intel Celeron - N3050 - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3050 / 1.6 GHz, up to 2.16 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, 10/100 Ethernet
- Battery
- 4-cell
- Black, blue
- 29.8 cm x 21.1 cm x 2.09 cm
- 1.58 kg
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- HDCP, glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- 10/100 Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 3270 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- USB 2.0 , Headphone output , HDMI , LAN , USB 3.0
- Memory Card Reader
- Yes (SD Card)
- Black, blue
- Accelerometer
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.58 kg
