The aluminum unibody plus Gorilla Glass 2 design of the Aspire S7 makes it incredibly slender, light and strong. It's the thinnest Ultrabook with a super-crisp Full HD touch display on the market. And, the dual-torque hinge keeps the display very stable when you use it for touch control.
The Aspire S7's Full HD display generates deep detail and puts 10-point touch control at your fingertips. This Ultrabook is made for teamwork: Open it to 180 degrees, punch a hotkey to flip the view, and you're in shape to share. Take the show to a big screen, wire-free, via newly featured WiDi connectivity.
Premium build
The aluminum unibody plus Gorilla Glass 2 design of the Aspire S7 makes it incredibly slender, light and strong. It's the thinnest Ultrabook with a super-crisp WQHD touch display on the market. And, the dual-torque hinge keeps the display very stable when you use it for touch control. -
Touch and show
The Aspire S7's WQHD display generates deep detail and puts 10-point touch control at your fingertips. This Ultrabook is made for teamwork: Open it to 180 degrees, punch a hotkey to flip the view, and you're in shape to share. Take the show to a big screen, wire-free, via newly featured WiDi connectivity. -
Quick and clear
You can work and play faster than ever on the Aspire S7, as it packs a RAID 0 solid state drive (SSD) with two times faster performance than standard SSDs.
- Acer Aspire Pro Series S7-393 - 13.3" - Intel Core i5 - 5200U - 8 GB RAM - 128 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 13.3" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 5500
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 11.5 hours
- Ambient light sensor
- White, silver
- 32.3 cm x 22.3 cm x 1.29 cm
- 1.3 kg
- Localisation
- Region: United Kingdom
- Product Type
- Ultrabook
- Operating System
- Windows 8.1 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HDCP, Corning Gorilla glass, anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, two microphones
- High Definition Audio, Dolby Digital Plus Home Theater
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Acer ZoomPerfect touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Technology
- 4-cell lithium polymer
- Capacity
- 47 Wh
- Run Time
- Up to 11.5 hours
- Battery Run Time
- Video playback: up to 8.5 hours , Web browsing over Wi-Fi: up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- 2 x USB 3.0 , HDMI , Acer converter port , Headphone output
- Memory Card Reader
- 2 in 1 (SD Card)
- White, silver
- Integrated Options
- MIMO technology, USB 3.0 port power off USB charging, Acer Purified.Voice technology
- Included Accessories
- Cleaning cloth, power adapter, carrying case
- Localization
- 1.3 kg
