Acer Aspire Pro R7-372T Core i7 6500U 8GB 128GB SSD 13.3" Windows 10 Professional
Quicklinx: C4XYWS00 Mfr#: NX.G8SEK.003
  • Core i7
  • IEEE 802.11n
The Aspire R7 convertible design immerses you directly in content. This slim, high-performance PC features the great Ezel hinge, which brings your touchscreen within easy reach whichever way you use it.
  • The Ezel hinge
    The Ezel hinge works just right - it provides low resistance for converting the Aspire R7 into four modes with just one hand, and higher resistance so the touchscreen stays steady when you use it. Work with the Aspire R7 at your desk as a notebook, flick it into display mode for sharing, or use it as a pad for drawing.
  • Ezel mode
    Ezel mode brings the touch display closer to you, so you don't have to reach across your desk to use it. Just pull the display up and out, where it can float over the keyboard. Having the display that much closer makes switching between touch control and typing that much easier.
  • Great sights and sounds
    The Aspire R7 delivers awesome sights and sounds, in every mode. The Full HD display makes details stand out, and powerful speakers plus Dolby Digital Plus blast the acoustic power of your notebook. In addition, audio channels automatically reverse when switching modes, so stereo sound is always perfect.
Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 128 GB SSD - UK
Notebook - flip-hinge design
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac
4-cell
Grey
34.38 cm x 23.035 cm x 1.85 cm
1.6 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6500U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
128 GB SSD M.2
Display
13.3"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Camera Features
HDR (High Dynamic Range), 720p HD movie recording
Sound
Stereo speakers, microphone
Dolby Digital Plus Home Theater
Audio Features
Output: Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
M.2 Card
4-cell
3315 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB 2.0 , 2 x USB 3.0 , HDMI , Headphone/microphone combo jack , Thunderbolt 3
Grey
Security lock slot (cable lock sold separately), volume control, Acer Purified.Voice technology, MU-MIMO technology
Power adapter
ACPI 5.0
Localization
1.6 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
