The Aspire R7 convertible design immerses you directly in content. This slim, high-performance PC features the great Ezel hinge, which brings your touchscreen within easy reach whichever way you use it.
The Ezel hinge
The Ezel hinge works just right - it provides low resistance for converting the Aspire R7 into four modes with just one hand, and higher resistance so the touchscreen stays steady when you use it. Work with the Aspire R7 at your desk as a notebook, flick it into display mode for sharing, or use it as a pad for drawing. -
Ezel mode
Ezel mode brings the touch display closer to you, so you don't have to reach across your desk to use it. Just pull the display up and out, where it can float over the keyboard. Having the display that much closer makes switching between touch control and typing that much easier. -
Great sights and sounds
The Aspire R7 delivers awesome sights and sounds, in every mode. The Full HD display makes details stand out, and powerful speakers plus Dolby Digital Plus blast the acoustic power of your notebook. In addition, audio channels automatically reverse when switching modes, so stereo sound is always perfect.
- Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook - flip-hinge design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 4-cell
- Grey
- 34.38 cm x 23.035 cm x 1.85 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 128 GB SSD M.2
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- Dolby Digital Plus Home Theater
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 4-cell
- Capacity
- 3315 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , 2 x USB 3.0 , HDMI , Headphone/microphone combo jack , Thunderbolt 3
- Grey
- Security lock slot (cable lock sold separately), volume control, Acer Purified.Voice technology, MU-MIMO technology
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
