Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With long lasting battery you stay connected all day. The E series allows you to do a touch more and travel a touch further.
Ultimate portability
Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With long lasting battery you stay connected all day. The E series allows you to do a touch more and travel a touch further. -
Optimized productivity
Finally, a laptop that can keep up with you. And the precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed. -
Sensational fun
Whether you're playing a game, recording a song or streaming a movie, the high-definition LED display and graphics capabilities enhance every multimedia experience.
- Acer Aspire ES 15 ES1-531-P8SP - 15.6" - Intel Pentium - N3700 - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Pentium N3700 / 1.6 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11b/g/n, Gigabit Ethernet
- Battery
- 3-cell
- Black
- 38.16 cm x 25.8 cm x 2.61 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Glare, CineCrystal
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 640 x 480
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell lithium polymer
- Capacity
- 3270 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 3.0 , HDMI , LAN , 2 x USB 2.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Black
- Wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
