Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. The E laptop allows you to do a touch more and travel a touch further. Acer's precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed.
Elegant outside
Their elegant exteriors, beautifully textured top covers, and hints of colors on their edges provide a unique, sophisticated look with a satisfying tactile feel. -
Flamboyant inside
Pop open the top covers and the flamboyant side of the notebooks will be revealed in a blast of color. The inside surfaces also feature textured patterns to offer a cohesive look and feel inside and out. -
Intuitive navigation
Enjoy a more intuitive navigation experience with this touchpad. It allows for smoother zooming and scrolling than regular touchpads.
- Acer Aspire ES 15 ES1-522-88WC - 15.6" - AMD A8 - 7410 - 8 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- AMD A8 7410 / 2.2 GHz, up to 2.5 GHz / 2 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R5
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11b/g/n, Gigabit Ethernet
- Battery
- 3-cell
- Black
- 38.16 cm x 25.8 cm x 2.715 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.5 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- AMD Turbo CORE technology
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Resolution
- 0.3 Megapixel
- Sound
- Microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Atheros WB335
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 3500 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Black
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
