Acer Aspire ES1-522 Quad Core A8-7410 8GB 1TB 15.6" Windows 10 Home
Quicklinx: C50GWS00 Mfr#: NX.G2LEK.002
  • IEEE 802.11n
Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. The E laptop allows you to do a touch more and travel a touch further. Acer's precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed.
  • Elegant outside
    Their elegant exteriors, beautifully textured top covers, and hints of colors on their edges provide a unique, sophisticated look with a satisfying tactile feel.
  • Flamboyant inside
    Pop open the top covers and the flamboyant side of the notebooks will be revealed in a blast of color. The inside surfaces also feature textured patterns to offer a cohesive look and feel inside and out.
  • Intuitive navigation
    Enjoy a more intuitive navigation experience with this touchpad. It allows for smoother zooming and scrolling than regular touchpads.
Acer Aspire ES 15 ES1-522-88WC - 15.6" - AMD A8 - 7410 - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Home 64-bit
AMD A8 7410 / 2.2 GHz, up to 2.5 GHz / 2 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R5
Keyboard
Integrated Webcam
Bluetooth, 802.11b/g/n, Gigabit Ethernet
3-cell
38.16 cm x 25.8 cm x 2.715 cm
2.4 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
AMD Turbo CORE technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R5
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - VGA
Resolution
0.3 Megapixel
Sound
Microphone
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Wireless Controller
Atheros WB335
Network Interface
Gigabit Ethernet
3-cell Lithium Ion
3500 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
2 x USB 2.0 , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Power adapter
Localization
2.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
