Acer Aspire ES1-420 AMD A4-5000 2GB 500GB 14" Windows 10 64-bit
Quicklinx: BQXMWS00 Mfr#: NX.G1GEK.013
  • Bluetooth 4.0
  • IEEE 802.11n
Aspire ES Series laptops are the perfect companions for work and play. With unique features like Acer BluelightShield software and optional M-DISC Ready optical drive, the Aspire ES Series keeps you ready for work and play. Precision Touchpad and Acer Chiclet Keyboard make sure you never miss a thing.
  • Great portability
    Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With many hours of battery you stay connected all day. The E series allows you to do a touch more and travel a touch further.
  • Optimized productivity
    Finally, a laptop that can keep up with you. Acer's touchpad and keyboard are designed specifically to improve accuracy and speed.
  • Sensational fun
    Whether you're playing a game, recording a song or streaming a movie, the high-definition LED display and graphics capabilities enhance every multimedia experience.
Acer Aspire ES1-420-55MS - 14" - AMD A4 - 5000 - 2 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Home 64-bit
AMD A4 5000 / 1.5 GHz / 2 MB Cache
2 GB DDR3L (1 x 2 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
14" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon HD 8330
Keyboard
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
4-cell
Red
34.3 cm x 24.5 cm x 2.92 cm
2.1 kg
Region: United Kingdom
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
2 GB (1 x 2 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
200 cd/m²
Glare, CineCrystal
Audio & Video
Graphics Processor
AMD Radeon HD 8330
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - VGA
Resolution
0.3 Megapixel
Sound
Microphone
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
2520 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
USB 3.0 , HDMI , LAN , USB 2.0
Memory Card Reader
Yes (SD Card)
Red
Power adapter
Localization
2.1 kg
