Aspire ES Series laptops are the perfect companions for work and play. With unique features like Acer BluelightShield software and optional M-DISC Ready optical drive, the Aspire ES Series keeps you ready for work and play. Precision Touchpad and Acer Chiclet Keyboard make sure you never miss a thing.
Great portability
Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With many hours of battery you stay connected all day. The E series allows you to do a touch more and travel a touch further. -
Optimized productivity
Finally, a laptop that can keep up with you. Acer's touchpad and keyboard are designed specifically to improve accuracy and speed. -
Sensational fun
Whether you're playing a game, recording a song or streaming a movie, the high-definition LED display and graphics capabilities enhance every multimedia experience.
- Acer Aspire ES1-420-55MS - 14" - AMD A4 - 5000 - 2 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- AMD A4 5000 / 1.5 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (1 x 2 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon HD 8330
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 4-cell
- Red
- 34.3 cm x 24.5 cm x 2.92 cm
- 2.1 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- RAM
- 2 GB (1 x 2 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 200 cd/m²
- Glare, CineCrystal
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Resolution
- 0.3 Megapixel
- Sound
- Microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 2520 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- USB 3.0 , HDMI , LAN , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Red
- Included Accessories
- Power adapter
- Localization
- 2.1 kg
