Enjoy improved accuracy and speed with this Acer Aspire laptop. Its textured surface allows you to grip it more easily, while its 3kg weight makes it’s the perfect lightweight and portable companion for when you’re working on the go.
The Acer Aspire E series offers you the best of both worlds: an attractive and sleek design, coupled with great features. From faster wireless networking for quicker browsing to speedy, increased data storage, as well as power-off USB charging, it packs everything you need into one small device.
With up to 16GB DDR3L SDRAM available, your applications will launch quickly while the 500GB hard drive provides ample storage space for your important projects.
Put your trust in BT Shop today and enjoy the full benefits of the Aspire E5-772 for less.
Ultimate portability
Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With long battery life you stay connected all day. The E series allows you to do a touch more and travel a touch further. -
Optimized productivity
Finally, a laptop that can keep up with you. Acer's precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed. -
Sensational fun
Whether you're playing a game, recording a song or streaming a movie, the high-definition LED display and graphics capabilities enhance every multimedia experience.
- Acer Aspire E 17 E5-772-53E4 - 17.3" - Intel Core i5 - 5200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 5500
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Grey, black
- 42.3 cm x 28.19 cm x 3.165 cm
- 3 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 2520 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , VGA , LAN , 2 x USB 3.0 , 2 x USB 2.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Grey, black
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, wake on LAN, USB 3.0 port power off USB charging
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 3 kg
