Product
Acer Aspire E5-574G Core i5-6200U 8GB 1TB 15.6" Windows 10 Home
Quicklinx: C507WS00 Mfr#: NX.G3HEK.001
  • Core i5
  • IEEE 802.11n
Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. The E series allows you to do a touch more and travel a touch further. Acer's precision touchpad and chiclet keyboard are designed specifically to improve accuracy and speed.
  • Ultimate portability
    Thin and with an easy grip, it's an ideal partner to go anywhere and work anytime. With long battery life you stay connected all day. And with AcerCloud you stay in sync with everything you need, automatically. The E series allows you to do a touch more and travel a touch further.
  • Optimized productivity
    Finally, a laptop that can keep up with you. Acer's Precision Touchpad and chiclet keyboard are designed specifically to improve accuracy and speed.
  • Sensational fun
    Whether you're playing a game, recording a song or streaming a movie, the high-definition LED display and graphics capabilities enhance every multimedia experience.
Acer Aspire E 15 E5-574G-51XK - 15.6" - Core i5 6200U - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce 940M
Video Memory
2 GB DDR3 VRAM
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell
Grey, black
38.16 cm x 25.6 cm x 2.92 cm
2.4 kg
Region: United Kingdom
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
NVIDIA GeForce 940M
Video Memory
2 GB DDR3 VRAM
Camera
Yes - HD
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
2520 mAh
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
HDMI , VGA , LAN , 2 x USB 3.0 , USB 2.0
Memory Card Reader
Yes (SD Card)
Grey, black
Wake on LAN, USB 3.0 port power off USB charging
Power adapter
Localization
2.4 kg
C507 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.89
C507 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.46
C507 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
C507 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.54
C507 C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.01
C507 C2G USB Superbooster Extender Kit In Stock £37.35
C507 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.11
C507 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
