The Aspire E series laptops provide a comprehensive computing experience for everyday users, with lots of appealing features and an attractive design that exceeds expectations. With many enhanced components and a textured surface, the Aspire E series is a good bit better at delivering a good bit more.
Beautiful form
A stylish textile pattern is enjoyable to the eye and pleasant to touch. Additional edge highlights emphasize the stylish look of the entire series and are complemented by the smart undercut design that is both good-looking and lets you easily raise the lid with just one hand. -
Sensational effects
With added media enhancements, you get an even richer media experience. The notebook features DVD SuperMulti optical drive and a Full HD display. -
Functions better
You get better, faster wireless networking, greatly improved touchpad usability and ample data storage. All this gives you added power and capability to get things done.
- Acer Aspire E 15 E5-574-58H3 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 1 TB Hybrid Drive - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 1 TB Hybrid Drive (8 GB flash) / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell
- Grey, black
- 38.16 cm x 25.6 cm x 2.92 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 1 TB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- HDCP, anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 2520 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , VGA , LAN , 2 x USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Grey, black
- Wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
