You can open this stylish touchscreen Chromebook all the way, until it becomes a tablet. On the way to 360 degrees of tablet fun, you can also stop to configure it as a stand-up display, or a tent-shaped display that lets you place it on a window sill so you can watch videos on the wide-viewing-angle screen while doing the dishes.
Bend it like you want it
The 360-degree hinge features dual-torque technology, so the panel is very easy to open, but locks in place when you tap, swipe and pinch on the touchscreen - for wobble-free touch control. The panel senses when you place it upside down for “tent mode”, prompting the image and audio channels to flip over automatically. -
Metallic style
The Chromebook R 11 sports a premium aluminum top panel that is made even more attractive with a unique engraving-like pattern. Acer uses special nano-imprint technology to create this sophisticated texturing that helps you to grip the notebook firmly - and which looks as good as it feels. -
Fast at everything
This Chromebook boasts very fast wireless connection speeds and longer signal ranges. It also features an impressive processor, giving it the power to support a super-fast USB 3.0 port. -
HD webcam
Being lightweight and thin, this stylish notebook floats like a butterfly and slips into your bag with ease. The Chromebook R 11’s built-in webcam allows for clearer photos and brighter video chats.
- Acer Chromebook R 11 CB5-132T-C0DF - 11.6" - Intel Celeron - N3050 - 2 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3050 / 1.6 GHz, up to 2.16 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell - up to 10 hours
- Accelerometer
- Security
- Trusted Platform Module (TPM) Security Chip
- White
- 29.4 cm x 20.4 cm x 1.92 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, Mercury free, Wide Viewing Angle, 25 ms response rate
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Technology
- 3-cell Lithium Ion
- Capacity
- 37 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- White
- Case Material
- Aluminum
- Integrated Options
- Accelerometer
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.6 kg
