Made for the cloud, this Acer Aspire portable laptop packs a lot of great features into a compact size. Its ultra-fast wireless connection keeps you productive whether you’re in the office, working at home or on the daily commute.
The Acer Aspire One brings you the ultimate Windows 10 experience, including the brand new Cortana personal digital assistant that responds to voice commands – so you can get the job done even when you’re hands-free.
Enjoy a 12-month subscription to Microsoft Office for free, as well as 1TB of online storage with Microsoft OneDrive – boosting your productivity two-fold!
At BT Shop, we understand how important storage can be to our customers, which is why this Acer notebook comes with in-built, expandable SSD storage in addition to Microsoft’s OneDrive. You can even set up further private cloud storage using the Build Your Own Cloud technology.
Want to use your Aspire One machine for calling? Enjoy crystal clear audio quality from the dual digital microphones wherever you are in the world.
Ideal for on-the-go usage, this 1.15kg laptop is lightweight, and at just 17.9mm wide, it’s slim enough to fit perfectly into your bag.
Speed-boosted wireless networking
With your head in the cloud, you have a need for speed. The Cloudbook has the latest wireless networking that supports faster-than-ever connection speeds. It makes your cloud storage speedy, your apps peppy and gives your browsing a big boost. -
Thin, and really light
Packing every feature you need into a beautiful, clean and simple design, the Cloudbook is just 17.9 mm thin. And at only 1.15 kg, this flyweight laptop not only fits perfectly in your bag, it won't drag you down either, wherever you go. -
Clear as a bell
The Cloudbook doesn't forget about audio quality either. Its dual digital microphones produce clear online calls, so they'll hear you loud and clear, from anywhere. And of course its powerful speakers provide more realistic and lifelike sound.
- Acer Aspire One Cloudbook 11 AO1-131-C5D5 - 11.6" - Intel Celeron - N3050 - 2 GB RAM - 32 GB eMMC
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3050 / 1.6 GHz, up to 2.16 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Battery
- 2-cell
- Grey
- 29.2 cm x 20.2 cm x 1.79 cm
- 1.15 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 640 x 480
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, two microphones
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 4350 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , USB 2.0 , USB 3.0 , Headphone output
- Memory Card Reader
- Yes (SD Card)
- Grey
- Included Accessories
- Power adapter
- Localization
- 1.15 kg
