The delicate cross-hair brush pattern delivers a beautifully inviting tactile finish. The precision touchpad is more responsive, helping you work more effectively. With extensive hard drive space, you can easily store and share your important projects and data.
The power of wireless
Maintain a strong, consistent wireless signal with the strategically placed 802.11ac wireless antenna. -
Relax your eyes
Filter out eye-straining blue light and work longer in comfort. -
Vibrant images
Crisp, true-to-life colors come alive in Full HD 1080p resolution.
- Acer Aspire 3 A315-51-50ML - 15.6" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 2-cell - up to 6.5 hours
- Obsidian black
- 38.16 cm x 25.9 cm x 2.16 cm
- 2.1 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 2280
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Glare, CineCrystal
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 2-cell lithium polymer
- Capacity
- 37 Wh
- Run Time
- Up to 6.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Obsidian black
- Case Material
- Polycarbonate, ABS plastic
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 2.1 kg
Sustainability Information
- TCO Certified
