Acer Aspire A315-51 i5-7200U 8GB 256GB SSD 15.6" Windows 10
Quicklinx: D9FVWS00 Mfr#: NX.GNPEK.010
  • Core i5
  • IEEE 802.11n
The delicate cross-hair brush pattern delivers a beautifully inviting tactile finish. The precision touchpad is more responsive, helping you work more effectively. With extensive hard drive space, you can easily store and share your important projects and data.
  • The power of wireless
    Maintain a strong, consistent wireless signal with the strategically placed 802.11ac wireless antenna.
  • Relax your eyes
    Filter out eye-straining blue light and work longer in comfort.
  • Vibrant images
    Crisp, true-to-life colors come alive in Full HD 1080p resolution.
Acer Aspire 3 A315-51-50ML - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
256 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
2-cell - up to 6.5 hours
Obsidian black
38.16 cm x 25.9 cm x 2.16 cm
2.1 kg
Region: United Kingdom
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
12 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Glare, CineCrystal
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - VGA
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
2-cell lithium polymer
37 Wh
Run Time
Up to 6.5 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
2 x USB 2.0 , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Obsidian black
Case Material
Polycarbonate, ABS plastic
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2.1 kg
