The Aspire Z1 series is the all-in-one that packs all the essential computing features you need in a slim and space-saving design - simple, functional, and affordable.
Slim, with everything inside
An Aspire Z1 all-in-one has everything you need, but it has a very small footprint so it frees up much more desk space than a typical desktop PC. This computer-monitor combination is built into a panel that is only 30 mm thick, and delivers a user-friendly and smooth computing experience. -
Full HD visuals, great audio
These slender computers are great for experiencing movies and all that the web has to offer. Their Full HD displays show your favorite scenes perfectly, and their Hi-Fi speakers have built-in subwoofers that produce powerful sound, for great cinematic experiences. -
Ergonomic and clutter-free
These all-in-ones all sport an adjustable stand that lets you choose the most comfortable way to view anything, from browsing the web to watching your favorite movie. They also have very convenient cable holes that help to route your PC cables, keeping your desk clean and organized.
- Acer Aspire Z1-623_QubCi34005U - all-in-one - Core i3 4005U 1.7 GHz - 4 GB - HDD 1 TB - LED 21.5"
- Personal computer - all-in-one
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (4th Gen) 4005U / 1.7 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 4400
- Networking
- 10Mb LAN, Bluetooth, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- 52.6 cm x 3.4 cm x 34.2 cm
- 4.3 kg
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Stereo speakers
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Response Time
- 5 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Resolution (MP)
- 1 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
Audio Input
- Microphone
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Slots
- 1 (total) / 0 (free) x CPU , SO-DIMM 204-pin
- 1 x LAN , 1 x HDMI input , 2 x USB 2.0 , 1 x USB 3.0
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 52.6 cm
- 3.4 cm
- 34.2 cm
- 4.3 kg
