Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP® 3D Ready2, while adhering to your bottom line.
- Acer A1200 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 235 Watt
- 31.5 cm x 21.4 cm x 9.8 cm
- 2.5 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Brightness (Reduced)
- 2720 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 65 cm - 762 cm
- Projection Distance
- 1 m - 9.1 m
- Throw Ratio
- 1.49 - 1.93:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz x 100 kHz
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A , 1 x serial RS-232 (management)
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 21.4 cm
- 9.8 cm
- 2.5 kg
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
