Privacy You Can Trust. Blacks out screen image when viewed from the side to prevent prying eyes from reading your screen. Crystal clear screen image from straight-on view. Easy to attach and remove with new and improved tabs. Protects screen from scratches and fingerprints. TAA compliant. Privacy filter fits widescreen monitors with a diagonal screen measurement of 24.0" (viewable area only) and a 16:9 aspect ratio. Filter dimensions are 20-15/16" W x 11-3/4" H.
- Fellowes PrivaScreen Blackout - display privacy filter - 24" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 24" wide
- 1-year warranty
- Product Type
- 24" wide
Display Filter
- Viewing Area Height
- 29.8 cm
- Viewing Area Width
- 53.2 cm
- Aspect Ratio
- 16:9
- Scratch Resistant
- Fingerprint-resistant coating
- Limited warranty - 1 year
