3M Framed Desktop Monitor Privacy Filters offer outstanding privacy protection; allowing only those directly in front of the monitor to see on-screen data. Anti-reflective surface reduces screen glare. Fits 23.6" to 24" diagonally measured LCD widescreen desktop monitors. Actual filter viewing area dimensions are 20 7/8" wide x 13 1/8" high (530mm x 333mm). Two easy-to-use attachment methods - 3M Command adhesive and attachable hanger arms. Helps protect the display from scratches and fingerprints. Easy to clean surface is smudge-resistant and repels permanent marker.
- 3M Lightweight LCD Privacy Filter PF324W - display privacy filter - 24" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 24" wide
- 1 year warranty
- Product Type
- 24" wide
Monitor Filter
- Viewing Area Height
- 33.3 cm
- Viewing Area Width
- 53 cm
- Aspect Ratio
- 16:10
- Anti-glare, anti-reflective
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
