Product
3M Privacy Filter 23" Wide
Quicklinx: 8QX3WS00 Mfr#: PF23.0W9
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M Privacy Filter PF23.0W9 - display screen filter - 23" wide
Display screen filter
Display Screen Size Compatibility
23" wide
61 cm 28.8 cm
1 year warranty
23" wide
61 cm 28.8 cm
1 year warranty
Service & Support Details
Limited warranty - 1 year
