3M PF27.0W LCD PRIVACY FILTER
Quicklinx: 81QRWS00 Mfr#: PF27.0W
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 27 1/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 22 15/16" wide x 14 5/16" high (582 mm x 364 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments. Limited 1-year warranty.
3M PF27.0W - display privacy filter - 27" wide
Display privacy filter
Display Screen Size Compatibility
27" wide
58.2 cm 36.4 cm
1 year warranty
27" wide
58.2 cm 36.4 cm
Anti-reflective, easy-to-remove
1 year warranty
Service & Support Details
Limited warranty - 1 year
