3M Extra Wide Adjustable Monitor Laptop Stand
Quicklinx: B5RSWS00 Mfr#: MS90B
Convenient stacking columns raise the monitor from 7/8" to 5 7/8" in increments of 1 5/8" to help ensure the proper viewing angle. Easily accommodate most laptops and office supplies with 16" clearance underneath the platform. It features no-skid base and is great for laptops, printers or monitors up to 17" or 40 lbs.
  • Sturdy construction
    Built with a reliable design, the stand can comfortably support up to 18.1 kg, ensuring stability for all your office equipment.
  • Height adjustment
    Easily adjust the height to find the most comfortable viewing position, reducing strain during long hours of use.
  • Versatile usage
    Designed for use with monitors, notebooks, and printers, this stand adapts to meet various needs in your workspace.
  • Space-saving design
    By elevating your devices, the stand helps maximize desk space, allowing for a more organized and clutter-free environment.
  • Recommended size
    Accommodates displays recommended for sizes up to 17 inches, making it suitable for most common office equipment.
3M Adjustable Monitor Stand Extra Wide MS90B stand - for monitor / notebook / printer - black, silver
Stand - desktop
45.7 cm
Adjustable Height
2.54-14.9 cm
Adjustments
Recommended Use
Monitor / notebook / printer
Recommended Display Size
17"
Max Load Weight
18.1 kg
Black, silver
45.7 cm
Adjustable Height
2.54-14.9 cm
Black, silver
AV Furniture
Stand
Recommended Use
Placing / Mounting
Desktop
17"
Adjustments
Max Load Weight
18.1 kg
Adjustable height
