Product
3M Anti-Glare Filter 21.5" Frameless
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 9XYNWS00 Mfr#: AG21.5W9
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 21 9/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 18 3/4" wide x 10 9/16" high (477 mm x 268 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG21.5W9 - display screen filter - 21.5" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
21.5" wide
1 year warranty
Package Content
Cleaning cloth
21.5" wide
Clear
Monitor Filter
Viewing Area Height
26.8 cm
Viewing Area Width
47.7 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
