3M Anti-Glare Filter 19.5" Widescreen Frameless
Quicklinx: 9XYRWS00 Mfr#: AG19.5W9
Discontinued, only used stock available
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 19 7/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 17" wide x 9 5/16" high (433 mm x 237 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG19.5W9 - display screen filter - 19.5" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
19.5" wide
1 year warranty
Package Content
Cleaning cloth
19.5" wide
Clear
Monitor Filter
Viewing Area Height
24 cm
Viewing Area Width
43.2 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
