Product
3M Anti-Glare Filter 19" Widescreen Frameless
Quicklinx: 9XYSWS00 Mfr#: AG19.0W
Accessory Type: Privacy Screen
Stock Status: Clearance, Used Stock
Hurry, only 1 left in stock!
£48.59 ex VAT
£58.30 inc VAT
Express delivery Delivered on Tuesday
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitor with a diagonally measured 18 15/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 16 1/16" wide x 10 1/16" high (408 mm x 255 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG19.0W - display screen filter - 19" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
19" wide
1 year warranty
Package Content
Cleaning cloth
19" wide
Clear
Monitor Filter
Viewing Area Height
25.5 cm
Viewing Area Width
40.8 cm
Aspect Ratio
16:10
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
3M Anti-Glare Filter 19 Bundle deal on 3M Anti-Glare Filter 19" Widescreen Frameless
£148.35
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9XYS 025723
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £6.82
Ref: 9XYS 034353
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £6.82
Ref: 9XYS 036014
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £6.82
Ref: 9XYS 037950
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £6.82
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: 3M
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
