Product
3M Anti-Glare Filter 19" Frameless
Quicklinx: 9XYQWS00 Mfr#: AG19.0
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit standard desktop LCD monitors with a diagonally measured 19" viewing screen and a 5:4 aspect ratio. Actual filter dimensions are 14 13/16" wide x 11 7/8" high (377 mm x 302 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG19.0 - display screen filter - 19"
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
19"
1 year warranty
Package Content
Cleaning cloth
19"
Clear
Monitor Filter
Viewing Area Height
30.2 cm
Viewing Area Width
37.7 cm
Aspect Ratio
5:4
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
