3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 27 9/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 23 3/8" wide x 14 5/8" high (594 mm x 371 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M PF28.0W - display privacy filter - 28" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 28" wide
- 59.4 cm 37.1 cm
- 1 year warranty
- Product Type
- 28" wide
- 59.4 cm 37.1 cm
- Anti-reflective, easy-to-remove
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£190.01
